Saltar al contenido principal
Samsung Galaxy S III Front-Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy S III Front-Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Front-Facing Camera Replacement: paso 2, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 2, imagen 2 de 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Front-Facing Camera Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 3, imagen 2 de 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Front-Facing Camera Replacement: paso 4, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 4, imagen 2 de 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Front-Facing Camera Replacement: paso 5, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 5, imagen 2 de 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Front-Facing Camera Replacement, Battery: paso 6, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement, Battery: paso 6, imagen 2 de 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Front-Facing Camera Replacement: paso 7, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 7, imagen 2 de 2
    • Remove the battery.
  8. Samsung Galaxy S III Front-Facing Camera Replacement, SIM Card: paso 8, imagen 1 de 3 Samsung Galaxy S III Front-Facing Camera Replacement, SIM Card: paso 8, imagen 2 de 3 Samsung Galaxy S III Front-Facing Camera Replacement, SIM Card: paso 8, imagen 3 de 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Front-Facing Camera Replacement: paso 9, imagen 1 de 3 Samsung Galaxy S III Front-Facing Camera Replacement: paso 9, imagen 2 de 3 Samsung Galaxy S III Front-Facing Camera Replacement: paso 9, imagen 3 de 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Front-Facing Camera Replacement, microSD Card: paso 10, imagen 1 de 3 Samsung Galaxy S III Front-Facing Camera Replacement, microSD Card: paso 10, imagen 2 de 3 Samsung Galaxy S III Front-Facing Camera Replacement, microSD Card: paso 10, imagen 3 de 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Front-Facing Camera Replacement: paso 11, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 11, imagen 2 de 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Front-Facing Camera Replacement, Plastic Midframe: paso 12, imagen 1 de 1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Front-Facing Camera Replacement: paso 13, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 13, imagen 2 de 2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Front-Facing Camera Replacement, Headphone Jack/Speaker Assembly: paso 14, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement, Headphone Jack/Speaker Assembly: paso 14, imagen 2 de 2
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Front-Facing Camera Replacement: paso 15, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 15, imagen 2 de 2
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Front-Facing Camera Replacement: paso 16, imagen 1 de 1
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
  17. Samsung Galaxy S III Front-Facing Camera Replacement, Motherboard Assembly: paso 17, imagen 1 de 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  18. Samsung Galaxy S III Front-Facing Camera Replacement: paso 18, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 18, imagen 2 de 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  19. Samsung Galaxy S III Front-Facing Camera Replacement: paso 19, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 19, imagen 2 de 2
    • Disconnect the display data cable from the motherboard.
  20. Samsung Galaxy S III Front-Facing Camera Replacement: paso 20, imagen 1 de 3 Samsung Galaxy S III Front-Facing Camera Replacement: paso 20, imagen 2 de 3 Samsung Galaxy S III Front-Facing Camera Replacement: paso 20, imagen 3 de 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  21. Samsung Galaxy S III Front-Facing Camera Replacement: paso 21, imagen 1 de 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  22. Samsung Galaxy S III Front-Facing Camera Replacement: paso 22, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 22, imagen 2 de 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
  23. Samsung Galaxy S III Front-Facing Camera Replacement, Front-Facing Camera: paso 23, imagen 1 de 1
    • Remove the single 2.0 mm Phillips screw securing the front-facing camera bracket to the front panel.
  24. Samsung Galaxy S III Front-Facing Camera Replacement: paso 24, imagen 1 de 2 Samsung Galaxy S III Front-Facing Camera Replacement: paso 24, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to lift the front-facing camera/ambient light sensor/rear microphone assembly out from its socket in the front panel assembly.
Conclusión
40 personas más completaron esta guía.
2 comentarios
I have an s3 & no matter what I do , the front facing camera will not work, help !!!
robertmyatt62@yahoo.com
robert myatt - Contestar
Yeah that's my problem too man. I did all the hard reset $@$* and nothing happened .
carlo jose guela - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 23,437
