Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Samsung Galaxy S II, utiliza nuestros manuales de servicio .
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: paso 1, imagen 1 de 3 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: paso 1, imagen 2 de 3 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: paso 1, imagen 3 de 3
    • The 4.3-inch super Amoled Plus display is simply gorgeous!
  2. Samsung Galaxy S II Teardown: paso 2, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 2, imagen 2 de 2
    • Look at how slim the phone is! Only 8.49mm thin!
    • Back cover is flexible but don't worry it will not break. It also has a nice texture to it.
  3. Samsung Galaxy S II Teardown: paso 3, imagen 1 de 1
    • Look at how compact everything is inside!
    • Remove the seven visible screws.
    • Then unclip the back panel starting on the left next to the audio jack. Go slowly.
  4. Samsung Galaxy S II Teardown: paso 4, imagen 1 de 3 Samsung Galaxy S II Teardown: paso 4, imagen 2 de 3 Samsung Galaxy S II Teardown: paso 4, imagen 3 de 3
    • Removing the back panel gives you an impressive and sophisticated view of the internals.
  5. Samsung Galaxy S II Teardown: paso 5, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 5, imagen 2 de 2
    • Removing the motherboard is as simple as it looks !
    • Unclip the 5 ribbon connectors and the antenna cable.
    • Then remove the 2 small black screws.
    • Don't forget to unglue the volume flex and power flex, they are attached to the motherboard. Otherwise the motherboard won't come out easily like it should.
  6. Samsung Galaxy S II Teardown: paso 6, imagen 1 de 3 Samsung Galaxy S II Teardown: paso 6, imagen 2 de 3 Samsung Galaxy S II Teardown: paso 6, imagen 3 de 3
    • The board with removed EMI shields.
    • The front.
    • ..and the back.
    • The front panel without the logic board.
    • The front facing camera part, the cinch-vibrator-1.mic part and the usb connection-2.mic-antenna board.
  7. Samsung Galaxy S II Teardown: paso 7, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 7, imagen 2 de 2
    • The camera connector is at the upper left corner in the second picture.
    • The power and volume buttons are soldered to the logic board.
    • View the picture in HQ if you want to be impressed!
  8. Samsung Galaxy S II Teardown: paso 8, imagen 1 de 1
    • This EMI shield is nearly a heat sink.
    • Should be useful with a 1.2GHz dual core under it!
  9. Samsung Galaxy S II Teardown: paso 9, imagen 1 de 3 Samsung Galaxy S II Teardown: paso 9, imagen 2 de 3 Samsung Galaxy S II Teardown: paso 9, imagen 3 de 3
    • The (tiny) 8MP camera.
    • It's smaller than an iPhone 4 camera.
  10. Samsung Galaxy S II Teardown: paso 10, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 10, imagen 2 de 2
    • The front-facing camera and the light sensor are a single part.
    • The front-facing camera is 2MP, which is better than the iPhone 4's VGA camera.
  11. Samsung Galaxy S II Teardown: paso 11, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 11, imagen 2 de 2
    • The vibrator, first mic (did you know there are two?), cinch plug and the earspeaker.
  12. Samsung Galaxy S II Teardown: paso 12, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 12, imagen 2 de 2
    • The USB-connection and 2 x mic board.
    • It's stuck with glue to the front panel.
    • The (only) antenna cable and a metal shield holding the light sensor in place.
  13. Samsung Galaxy S II Teardown: paso 13, imagen 1 de 2 Samsung Galaxy S II Teardown: paso 13, imagen 2 de 2
    • This is it.
    • It still works after reassembly!
lon
Miembro Desde 03/19/11
2,867 Reputación
2 Guías creadas
19 comentarios
Why not show the great display? =\
Diego Sampaio - Contestar
Do you see the NFC module ? (the phone come frome England?)
Beacause there is a big disscution between ethier the NFC is not implemented on phone, maybe the chip is on ?
Forever TPC - Contestar
no, it should be from germany, I bought it there ;)
lon -
I'll change it for you ;)
lon -
Where can I purchase any mobile NFC chip and solder on to Galaxy S2 International version (I9100)?
Tai Li -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 33
Ultimos 30 días: 139
Todo El Tiempo: 562,982
