Saltar al contenido principal
Introducción
The media card stores pictures, videos, music, sounds, and downloads. While this card is not vital to the operation of the phone it is still a useful addition to the phone.
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. To remove the rear cover, locate the tab indicated by the red outline. Using your fingernail, gently pry the rear cover. Using your fingernail, gently pry the rear cover.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Skip the upgrade.
    Descuento de $10 en tu factura de $50 con
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
  3. The media card is found inside the area indicated with the red rectangle.  The card itself is small and black making it hard to easily see. After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal. After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
Conclusión
Una persona más ha completado esta guía.
Joshua King
Miembro Desde 26/03/14
1,330 Reputación
9 Guías creadas
Equipo
Clemson, Team 1-5, Benson Spring 2014 Miembro de Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 367
