Saltar al contenido principal
Samsung Galaxy S II T989 Inner Plate Replacement
Qué necesitas
  1. Samsung Galaxy S II T989 Inner Plate Replacement, Rear Cover: paso 1, imagen 1 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Rear Cover: paso 1, imagen 2 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Rear Cover: paso 1, imagen 3 de 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Inner Plate Replacement, SIM Card: paso 2, imagen 1 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, SIM Card: paso 2, imagen 2 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, SIM Card: paso 2, imagen 3 de 3
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
  3. Samsung Galaxy S II T989 Inner Plate Replacement, Media Card: paso 3, imagen 1 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Media Card: paso 3, imagen 2 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Media Card: paso 3, imagen 3 de 3
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
  4. Samsung Galaxy S II T989 Inner Plate Replacement, Battery: paso 4, imagen 1 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Battery: paso 4, imagen 2 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Battery: paso 4, imagen 3 de 3
    • Turn off the phone before removing battery.
    • The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
    • After the battery starts to lift upwards, use your hand to hold and remove it.
  5. Samsung Galaxy S II T989 Inner Plate Replacement, Inner Plate: paso 5, imagen 1 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Inner Plate: paso 5, imagen 2 de 3 Samsung Galaxy S II T989 Inner Plate Replacement, Inner Plate: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  6. Samsung Galaxy S II T989 Inner Plate Replacement: paso 6, imagen 1 de 3 Samsung Galaxy S II T989 Inner Plate Replacement: paso 6, imagen 2 de 3 Samsung Galaxy S II T989 Inner Plate Replacement: paso 6, imagen 3 de 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
Conclusión
Joshua King
Miembro Desde 03/26/14
1,378 Reputación
9 Guías creadas
Equipo
Clemson, Team 1-5, Benson Spring 2014 Miembro de Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 1,409
