Saltar al contenido principal
Samsung Galaxy S Blaze Volume Rocker Replacement
Qué necesitas
  1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: paso 1, imagen 1 de 1
    • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
  2. Samsung Galaxy S Blaze Volume Rocker  Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the device and set aside.
  3. Samsung Galaxy S Blaze Volume Rocker  Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: paso 3, imagen 2 de 2
    • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Volume Rocker  Replacement: paso 4, imagen 1 de 1
    • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze Volume Rocker  Replacement: paso 5, imagen 1 de 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: paso 5, imagen 2 de 2
    • The volume rocker is held into the frame by two small prongs.
    • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
    • The prongs on the volume rocker look like this.
Conclusión
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Una persona más ha completado esta guía.
Jake Best
Miembro Desde 03/05/15
261 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 308
