Saltar al contenido principal
Samsung Galaxy S Blaze SD Card Slot Cover Replacement
Qué necesitas
  1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement, SD Card Slot Cover: paso 1, imagen 1 de 1
    • Make sure the device is powered off and not plugged into a power source.
    • Remove the back plate to reveal the battery.
  2. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 2, imagen 1 de 1
    • Use a spudger or your fingers to remove the battery from the phone.
  3. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws from the device frame.
  4. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 4, imagen 1 de 1
    • Use the blue plastic opening tool to gently pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 5, imagen 1 de 2 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 5, imagen 2 de 2
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
Conclusión
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 personas más completaron esta guía.
Rene Bolanos
Miembro Desde 03/05/15
435 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 366
