Use a Phillips head screwdriver size 00.
Remove the 4mm screws from the frame. The screws can be removed in any order.
The eight screws are all the same size.
Use the blue plastic opening tool to remove the frame from the device.
Work around the device with the opening tool until the frame is completely off the device.
You may need to use some force to pry the frame off of the device.
The motherboard is held onto the device by 4 ribbon cable connectors.
The first 3 ribbon cable connectors are on the same side.
Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
Turn the motherboard over to reveal the last ribbon cable connector.
Unlatch the final ribbon cable connector with the blue plastic opening tool.
Remove the motherboard from the device.
Incrustar esta guía
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Vista previa
