Saltar al contenido principal
Samsung Galaxy S Blaze Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S Blaze Motherboard Replacement: paso 3, imagen 2 de 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: paso 5, imagen 1 de 3 Samsung Galaxy S Blaze Motherboard Replacement: paso 5, imagen 2 de 3 Samsung Galaxy S Blaze Motherboard Replacement: paso 5, imagen 3 de 3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: paso 6, imagen 1 de 1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
Conclusión
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 personas más completaron esta guía.
Rene Bolanos
Miembro Desde 03/05/15
435 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 799
