Saltar al contenido principal
Samsung Galaxy R Front Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Front Facing Camera Replacement, Battery: paso 2, imagen 1 de 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: paso 2, imagen 2 de 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: paso 2, imagen 3 de 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: paso 3, imagen 1 de 2 Samsung Galaxy R Front Facing Camera Replacement, Remove screws: paso 3, imagen 2 de 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: paso 4, imagen 1 de 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: paso 4, imagen 2 de 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: paso 4, imagen 3 de 3
    • The front facing camera is located in the top right corner of the back of the phone.
    • To remove the camera, gently pull until it detaches from the motherboard.
Conclusión
2 personas más completaron esta guía.
Keon Horahan
Miembro Desde 10/13/14
841 Reputación
6 Guías creadas
Equipo
Clemson, Team 3-3, Benson Fall 2014 Miembro de Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 387
