Saltar al contenido principal
Samsung Galaxy Prime Battery Replacement
Qué necesitas
  1. Samsung Galaxy Prime Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Insert a small spudger or fingernail into the tab that is located on the power button side of the phone and then try to pry up.
    • After the initial lift, go around the edges of the back cover lifting it up to release.
  2. Samsung Galaxy Prime Battery Replacement: paso 2, imagen 1 de 1
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Prime Battery Replacement: paso 3, imagen 1 de 1
    • Insert the new battery in the reverse order from taking out the battery, ensuring the metal contacts from the phone are touching the flat metal contacts on the battery. Then place another edge of battery in the bay.
Conclusión
Una persona más ha completado esta guía.
Equipo
UW Tacoma, Team S1-G1, Liner Summer 2018 Miembro de UW Tacoma, Team S1-G1, Liner Summer 2018
UWT-LINER-SU18S1G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 47
Todo El Tiempo: 1,394
