Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Prevail Rear Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Prevail Rear Speaker Replacement, Rear Speaker: paso 1, imagen 1 de 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Speaker Replacement: paso 2, imagen 1 de 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Speaker Replacement: paso 4, imagen 1 de 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The motherboard will now be accessible.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Speaker Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Prevail Rear Speaker Replacement: paso 5, imagen 2 de 2
    • Using the spudger, carefully lift upward to remove the speaker assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
Conclusión
Una persona más ha completado esta guía.
Ricardo Zuloaga
Miembro Desde 09/15/16
537 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 17-6, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 379
