Saltar al contenido principal
Samsung Galaxy Prevail Rear Camera Lens Replacement
Qué necesitas
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: paso 1, imagen 1 de 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: paso 2, imagen 1 de 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: paso 3, imagen 1 de 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: paso 4, imagen 1 de 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: paso 5, imagen 1 de 1
    • Replace the secondary rear panel which has the camera lens attached.
Conclusión
Ricardo Zuloaga
Miembro Desde 09/15/16
525 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 17-6, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 267
