Saltar al contenido principal
Samsung Galaxy Prevail Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Prevail Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Using the nylon spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Using the spudger lift the speaker assembly upward, so you may have access to the headphone assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
  6. Samsung Galaxy Prevail Headphone Jack Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Prevail Headphone Jack Replacement: paso 6, imagen 2 de 2
    • Using the spudger, carefully unplug and remove the headphone port assembly by lifting upward on the ribbon cable.
    • The headphone jack should lift off of the motherboard.
Conclusión
Una persona más ha completado esta guía.
Ricardo Zuloaga
Miembro Desde 09/15/16
525 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 17-6, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 302
