Saltar al contenido principal
Samsung Galaxy Prevail 2 Vibrator Replacement
Qué necesitas
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: paso 1, imagen 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: paso 1, imagen 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: paso 1, imagen 3 de 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: paso 2, imagen 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: paso 2, imagen 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: paso 3, imagen 1 de 2 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: paso 3, imagen 2 de 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: paso 4, imagen 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: paso 4, imagen 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: paso 4, imagen 3 de 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: paso 5, imagen 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: paso 5, imagen 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: paso 5, imagen 3 de 3
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: paso 6, imagen 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: paso 6, imagen 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: paso 6, imagen 3 de 3
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: paso 7, imagen 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: paso 7, imagen 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: paso 7, imagen 3 de 3
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: paso 8, imagen 1 de 1
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
Conclusión
5 personas más completaron esta guía.
Garrett Bowleg
Miembro Desde 10/08/14
469 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-4, Leahy Fall 2014 Miembro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,012
