Saltar al contenido principal
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: paso 1, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: paso 1, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: paso 1, imagen 3 de 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: paso 2, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: paso 2, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: paso 3, imagen 1 de 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: paso 3, imagen 2 de 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: paso 4, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: paso 4, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: paso 4, imagen 3 de 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: paso 5, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: paso 5, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: paso 5, imagen 3 de 3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: paso 6, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: paso 6, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: paso 6, imagen 3 de 3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: paso 7, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: paso 7, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: paso 7, imagen 3 de 3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: paso 8, imagen 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: paso 8, imagen 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: paso 8, imagen 3 de 3
    • Carefully lift and remove the camera from its position.
Conclusión
8 personas más completaron esta guía.
Equipo
USF Tampa, Team 14-4, Leahy Fall 2014 Miembro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 1,409
