Saltar al contenido principal
Samsung Galaxy Prevail 2 Home Button Replacement
Qué necesitas
  1. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: paso 1, imagen 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: paso 1, imagen 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: paso 1, imagen 3 de 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: paso 2, imagen 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: paso 2, imagen 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: paso 3, imagen 1 de 2 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: paso 3, imagen 2 de 2
    • Unscrew all of the screws.
    • Be sure to set aside in a safe place.
  4. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: paso 4, imagen 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: paso 4, imagen 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: paso 4, imagen 3 de 3
    • Insert the plastic opening tool between the silver frame and the white face of the phone to pry off the front face.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone
  5. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: paso 5, imagen 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: paso 5, imagen 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: paso 5, imagen 3 de 3
    • With the plastic opening tool, lift up the flap to to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: paso 6, imagen 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: paso 6, imagen 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: paso 6, imagen 3 de 3
    • With the plastic opening tool, lift the second flap up.
  7. Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: paso 7, imagen 1 de 2 Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: paso 7, imagen 2 de 2
    • Choose the motherboard side that contains the home button, as shown in the image.
  8. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: paso 8, imagen 1 de 2 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: paso 8, imagen 2 de 2
    • Use the plastic opening tool to push the home button out.
    • Push the button from the face of the phone inwards as indicated in the first image.
Conclusión
6 personas más completaron esta guía.
Garrett Bowleg
Miembro Desde 10/08/14
469 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-4, Leahy Fall 2014 Miembro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 2,080
