Introducción
The Samsung Galaxy On5 comes with two cameras. One as a front-facing camera and the second one with a rear-facing camera. For this guide, you will need a plastic pry tool, a PH00 Philip head screw driver, and your fingers to pull out the cameras.
  1. First locate the side notch for the back cover opening.
    • First locate the side notch for the back cover opening.
    • Make sure the phone is powered down before moving on to remove the battery.
  2. Use any tool, mostly a plastic tool to pop open the back cover off the phone.
    • Use any tool, mostly a plastic tool to pop open the back cover off the phone.
    • Caution be careful not to cut yourself while using a pry tool.
    • Locate the battery notch to remove the battery
    • Please be sure that the phone is powered down.
    • Be careful not puncture the battery. Lithium-ion battery are flammable and can irritate your skin if it come in contact.
    • Use a pry tool to pry out the battery from the house of where it sit.
    • Using a metal pry can possibly puncture the battery.
    • Once the battery is released from its housing, you can use to fingers to pull it out and place it aside.
    • Your are complete with disassembling your phone battery. If you have a replacement battery work backwards to reinsert the new battery into its housing.
    • Before dissembling the phone take out the SIM card and microSD card.
    • Use a plastic pry tool to slide both cards out.
    • Do not use a metal pry tool. Use of one can cause damage to the cards or the pins with the cards holder.
    • Take the plastic Spudger tool to pry open the LCD ribbon cable cover.
    • This part might be a little hard to open. Take your time and be careful not to push too hard, so there's no damage to the ribbon cable
    • Once the cover is remove, place the cover aside so its not miss placed
    • Take a plastic pry tool and work towards the top right of the LCD ribbon cable to pry the cable from the logic board.
    • Do not use a metal pry tool. Metal pry tools can cause damage to the logic board and to the ribbon cable.
    • This cable send signal from the logic board to the LCD screen.
    • Once unplugged move the cable aside.
    • Take a PH00 Philip head and remove all 9 screws. Once done place them aside where you won't lose them.
    • All 9 screws are the same size.
    • Use iFixit plastic picks to pry away the LCD from the bask assembly.
    • This process will take a bit due to the glue thats holding the LCD and back assembly together. Slowly move around the edge go the screen to loosen the glue up.
    • If you have a heat gun, you can use the heat gun heat up the glue. That will make the use of the plastic picks easy to pry the pieces apart.
    • Once both the LCD and back assemble come apart, look at the back assembly which the speaker is located.
    • Once located take a the plastic pry tool to remove the speaker of its housing. And replace it with a new one.
    • Take a plastic pry tool to lift up the the front-facing camera from its housing.
    • Using a metal pry tool can cause damage to the logic board or to the ribbon cable connection.
      • Best practices is to use plastic pry tool over metal tools when work on delicate devices.
    • Once the camera is out of the housing it once was in. Use your fingers to pull out the camera from its connection on the logic board.
    • Best practices is if your can pull it out with your fingers use your fingers. Because using metal tool can cause damage.
    • You are complete in removing the front-facing camera. Now it's time to remove the rear-facing camera.
    • Take a PH00 Philips head screw driver and remove the screw.
    • When using a metal tool be aware of where you'r placing the bit. Damage to the motherboard will cause it to become inoperable.
    • Next use a plastic pry tool to disconnect the headphone ribbon from the motherboard.
    • Once that done you can remove the motherboard from the LCD housing. By lifting up from any ends of the logic board.
    • Flip the motherboard to where the camera lens is facing down and not at you.
    • Once thats done you can use your finger to remove camera from its connection from the motherboard.
    • And now you are done disassembling the camera from the motherboard. Work backwards to replace the cameras that are inoperable.
Conclusión
Una persona más ha completado esta guía.
Equipo
Gateway, Team S1-G5, Luster Fall 2018 Miembro de Gateway, Team S1-G5, Luster Fall 2018
GCC-LUSTER-F18S1G5
1 Miembro
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 46
Todo El Tiempo: 58
