Saltar al contenido principal
Samsung Galaxy Note5 Volume Button Replacement
Qué necesitas
  1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: paso 1, imagen 1 de 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Volume Button Replacement: paso 2, imagen 1 de 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Volume Button Replacement, Power Button: paso 3, imagen 1 de 1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Volume Button Replacement: paso 4, imagen 1 de 1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Volume Button Replacement: paso 5, imagen 1 de 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Volume Button Replacement: paso 6, imagen 1 de 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Volume Button Replacement: paso 7, imagen 1 de 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Volume Button Replacement: paso 8, imagen 1 de 1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Volume Button Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Note5 Volume Button Replacement: paso 9, imagen 2 de 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Volume Button Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Note5 Volume Button Replacement: paso 10, imagen 2 de 2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Volume Button Replacement: paso 11, imagen 1 de 2 Samsung Galaxy Note5 Volume Button Replacement: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Volume Button Replacement: paso 12, imagen 1 de 1
    • Push out the power button with the tip of the tweezers.
  13. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: paso 13, imagen 1 de 2 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: paso 13, imagen 2 de 2
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  14. Samsung Galaxy Note5 Volume Button Replacement: paso 14, imagen 1 de 1
    • Push out the volume button and remove it from the device.
Conclusión
3 personas más completaron esta guía.
Bernice Nunez
Miembro Desde 04/19/18
361 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S25-G17, Maness Spring 2018 Miembro de Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 1,425
