Introducción
Use this guide to replace the rear cover on your Samsung Galaxy Note10+.
Qué necesitas
Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
10 personas más completaron esta guía.
2 comentarios
Depending on how rough you back glass is. Mine was a shattered mess. It might take almost 2 hours. But mine was a worst case scenario. But be patient and slow and you are sure to be rewarded with a beautiful new back glass! Keep at it my friends! No need to ditch that phone yet!
Great tutorial, I replace real cover with battery. Now my Note list like new.
