Introducción
Check the device's troubleshooting page before replacing the SIM card. Also make sure you are installing the correct SIM card.
You may want to install a new SIM card if you change carriers, want a new phone number, cannot make calls, or cannot receive service anywhere.
Qué necesitas
Make sure the screen is face-down and the camera is opposite you.
Insert the flat end of a spudger into the phone's top right rectangular slot.
Use the spudger as a lever to pry open the back of the phone.
Pull out the (white and blue) SIM card directly above the empty battery slot.
Una persona más ha completado esta guía.
