Saltar al contenido principal
Samsung Galaxy Note Pro 12.2 Speakers Replacement
Qué necesitas
  1. Samsung Galaxy Note Pro 12.2 Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Make sure the device is powered off before starting repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Speakers Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Note Pro 12.2 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the one 3mm Phillips #00 screw securing the black speaker.
  3. Samsung Galaxy Note Pro 12.2 Speakers Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, pop the black speaker up and away from the device.
  4. Samsung Galaxy Note Pro 12.2 Speakers Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Note Pro 12.2 Speakers Replacement: paso 4, imagen 2 de 2
    • Remove the two 3mm screws securing the white speaker with the Phillips #00 screwdriver.
  5. Samsung Galaxy Note Pro 12.2 Speakers Replacement: paso 5, imagen 1 de 1
    • Using the blue opening tool pop the white speaker up and away from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 438
