Saltar al contenido principal
Samsung Galaxy Note Pro 12.2 SD Port Replacement
Qué necesitas
  1. Samsung Galaxy Note Pro 12.2 SD Port Replacement, SD Port: paso 1, imagen 1 de 1
    • Turn off your device before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 2, imagen 2 de 2
    • Pop up the orange tab connected to the SD port with the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 3, imagen 2 de 2
    • Remove the one 3mm Phillips #00 screw connected to the SD port.
  4. Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Pop open the orange wire tab connected to the SD port with the plastic opening tool.
    • If there is tape covering your tab, remove it with the tweezers before you pop open the tab.
  5. Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 5, imagen 2 de 2
    • Using the orange tab, pull the SD port up and away from the device.
  6. Samsung Galaxy Note Pro 12.2 SD Port Replacement: paso 6, imagen 1 de 1
    • Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
    • There is a little indent below the orange tab to help get under this piece. It may be difficult to remove, push up hard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 500
