Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Note Midframe Replacement
Qué necesitas
  1. Samsung Galaxy Note Midframe Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement, Rear Case: paso 1, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  2. Samsung Galaxy Note Midframe Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement: paso 2, imagen 2 de 2
    • Lift and remove the rear case from the phone.
  3. Samsung Galaxy Note Midframe Replacement, Battery: paso 3, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement, Battery: paso 3, imagen 2 de 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  4. Samsung Galaxy Note Midframe Replacement, MicroSD Card: paso 4, imagen 1 de 3 Samsung Galaxy Note Midframe Replacement, MicroSD Card: paso 4, imagen 2 de 3 Samsung Galaxy Note Midframe Replacement, MicroSD Card: paso 4, imagen 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note Midframe Replacement: paso 5, imagen 1 de 1
    • Remove the microSD card from its slot in the midframe.
  6. Samsung Galaxy Note Midframe Replacement, SIM Card: paso 6, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement, SIM Card: paso 6, imagen 2 de 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  7. Samsung Galaxy Note Midframe Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement: paso 7, imagen 2 de 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  8. Samsung Galaxy Note Midframe Replacement, Midframe: paso 8, imagen 1 de 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  9. Samsung Galaxy Note Midframe Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement: paso 9, imagen 2 de 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  10. Samsung Galaxy Note Midframe Replacement: paso 10, imagen 1 de 3 Samsung Galaxy Note Midframe Replacement: paso 10, imagen 2 de 3 Samsung Galaxy Note Midframe Replacement: paso 10, imagen 3 de 3
    • Slide the plastic opening tool down the seam.
  11. Samsung Galaxy Note Midframe Replacement: paso 11, imagen 1 de 3 Samsung Galaxy Note Midframe Replacement: paso 11, imagen 2 de 3 Samsung Galaxy Note Midframe Replacement: paso 11, imagen 3 de 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  12. Samsung Galaxy Note Midframe Replacement: paso 12, imagen 1 de 2 Samsung Galaxy Note Midframe Replacement: paso 12, imagen 2 de 2
    • Remove the midframe from the display assembly.
Conclusión
16 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
477,236 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
25,686 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 87
Todo El Tiempo: 11,291
