Saltar al contenido principal
Samsung Galaxy Note II Front Facing Camera Assembly Replacement
Qué necesitas
  1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: paso 1, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: paso 1, imagen 2 de 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: paso 2, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: paso 2, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 3, imagen 3 de 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: paso 4, imagen 1 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: paso 4, imagen 2 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: paso 4, imagen 3 de 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: paso 5, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: paso 5, imagen 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 6, imagen 1 de 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Midframe: paso 7, imagen 1 de 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 8, imagen 1 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 8, imagen 2 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 8, imagen 3 de 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 9, imagen 1 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 9, imagen 2 de 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 9, imagen 3 de 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 10, imagen 2 de 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 11, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 11, imagen 2 de 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 12, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 12, imagen 2 de 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 13, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 13, imagen 2 de 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 14, imagen 1 de 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 14, imagen 2 de 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: paso 15, imagen 1 de 1
    • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
  16. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 16, imagen 1 de 1
    • Remove the front-facing camera bracket.
  17. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 17, imagen 1 de 1
    • Use the flat end of a spudger to disconnect the front-facing camera connector.
  18. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: paso 18, imagen 1 de 1
    • Remove the front-facing camera.
Conclusión
13 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
467,548 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,074 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 11,804
