Introducción
Use this guide to replace or remove e front-facing camera from a Samsung Galaxy Note II.
Herramientas
Partes
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
12 personas más completaron esta guía.
