Introducción
The Vibration motor causes the phone to vibrate and provides the user with haptic feedback during phone use.
Qué necesitas
Power down your device and make sure that it is turned off.
Place the phone with the screen facing down on a clean flat surface.
Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
Remove the stylus from the stylus holder.
Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
Insert your spudger into the stylus socket and pry the midframe from the phone.
Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
Insert the sharp end of the spudger underneath the golden cables connecting the vibration motor. Gently pry upwards to disconnect them.
Una persona más ha completado esta guía.
