Saltar al contenido principal
Samsung Galaxy Note Display Assembly Replacement
Qué necesitas
  1. Samsung Galaxy Note Display Assembly Replacement, Stylus: paso 1, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Stylus: paso 1, imagen 2 de 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Display Assembly Replacement, Rear Case: paso 2, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Rear Case: paso 2, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Display Assembly Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 3, imagen 2 de 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Display Assembly Replacement, Battery: paso 4, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Battery: paso 4, imagen 2 de 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: paso 5, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: paso 5, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: paso 5, imagen 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Display Assembly Replacement: paso 6, imagen 1 de 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Display Assembly Replacement, SIM Card: paso 7, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement, SIM Card: paso 7, imagen 2 de 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Display Assembly Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 8, imagen 2 de 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Display Assembly Replacement, Midframe: paso 9, imagen 1 de 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Display Assembly Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 10, imagen 2 de 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Display Assembly Replacement: paso 11, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 11, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 11, imagen 3 de 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Display Assembly Replacement: paso 12, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 12, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 12, imagen 3 de 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Display Assembly Replacement: paso 13, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 13, imagen 2 de 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Display Assembly Replacement, Motherboard Assembly: paso 14, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Motherboard Assembly: paso 14, imagen 2 de 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Display Assembly Replacement: paso 15, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 15, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 15, imagen 3 de 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Display Assembly Replacement: paso 16, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 16, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 16, imagen 3 de 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Display Assembly Replacement: paso 17, imagen 1 de 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Display Assembly Replacement: paso 18, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 18, imagen 2 de 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Display Assembly Replacement, Display Assembly: paso 19, imagen 1 de 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  20. Samsung Galaxy Note Display Assembly Replacement: paso 20, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 20, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  21. Samsung Galaxy Note Display Assembly Replacement: paso 21, imagen 1 de 1
    • Using tweezers, or your fingers, remove the front-facing camera assembly.
  22. Samsung Galaxy Note Display Assembly Replacement: paso 22, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 22, imagen 2 de 2
    • Use the tip of a spudger to pry the headphone jack/earpiece speaker assembly out of its recess in the display assembly.
  23. Samsung Galaxy Note Display Assembly Replacement: paso 23, imagen 1 de 1
    • Use tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly.
  24. Samsung Galaxy Note Display Assembly Replacement: paso 24, imagen 1 de 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  25. Samsung Galaxy Note Display Assembly Replacement: paso 25, imagen 1 de 1
    • Lift the speaker enclosure from the display assembly.
  26. Samsung Galaxy Note Display Assembly Replacement: paso 26, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 26, imagen 2 de 2
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
  27. Samsung Galaxy Note Display Assembly Replacement: paso 27, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 27, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 27, imagen 3 de 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
  28. Samsung Galaxy Note Display Assembly Replacement: paso 28, imagen 1 de 1
    • Remove the USB board.
  29. Samsung Galaxy Note Display Assembly Replacement: paso 29, imagen 1 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 29, imagen 2 de 3 Samsung Galaxy Note Display Assembly Replacement: paso 29, imagen 3 de 3
    • Insert the tip of a spudger under the vibrator connector cable near the contacts then slide toward the vibrator itself.
  30. Samsung Galaxy Note Display Assembly Replacement: paso 30, imagen 1 de 2 Samsung Galaxy Note Display Assembly Replacement: paso 30, imagen 2 de 2
    • Insert the flat end of a spudger under the vibrator connector cable, and pry it up from the adhesive.
  31. Samsung Galaxy Note Display Assembly Replacement: paso 31, imagen 1 de 1
    • Remove the vibrator from the display assembly.
Conclusión
42 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
467,548 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,074 Guías creadas
6 comentarios
étape 31 ensuite ??
Fabrice - Contestar
i have a galaxy not and its display is badly broken,at the top of the phone(front side),the display is broken so badly that i am able to a little circuit i.e. a brown color wire which is connected to the display.
so my ques. is that can the phone work after repairing or it has gone?
Abhishek Kumbhar - Contestar
Hello Abhishek Kumbhar, if the motherboard is not damaged it's all fine. All other parts are replaceable
Georg Fischer - Contestar
excellent photos
of samsung 717
murali maroju - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 44,218
