Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The headphone jack is the port you connect your headphone to in order to receive the sound from the tablet through headphones. Over time, the headphone jack or the terminal connections can become worn out or damaged, which may result in headphones not receiving sound properly. In this case, the headphone jack has to be replaced and this guide will show you how.
  1. Remove the Samsung S-Pen stylus.
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Remove the 8 Phillips#00 3-mm screws holding the battery in place. Remove the 8 Phillips#00 3-mm screws holding the battery in place.
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Lift the top left corner of the battery up by the black tab.
    • Lift the top left corner of the battery up by the black tab.
  6. Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver. Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
    • Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
  8. Gently pry up the teal connector. Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
    • Gently pry up the teal connector.
    • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  9. Gently pry up the gold connector. Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
    • Gently pry up the gold connector.
  10. Remove the headphone jack from it's housing.
    • Remove the headphone jack from it's housing.
    • If difficult, use a plastic opening tool to pry up.
Conclusión
6 personas más completaron esta guía.
Joel
Miembro Desde 23/09/14
1,823 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 12-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Miembros
16 Guías creadas
Lightning struck while my son was on his tablet... no more headset audio? Replaced recommend parts still no audio. Plays fine without earbuds??? Insurance claim? What else could be the issue? Motherboard?
Shasta - Contestar
what are these connectors on the left side of headphone jack which are connected to the backside plate?
sanco - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 32
Todo El Tiempo: 6,225
