Saltar al contenido principal
Samsung Galaxy Note 5 Back Cover Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: paso 1, imagen 1 de 1
    • Heat the back cover to melt the strong adhesive sticker underneath.
  2. Samsung Galaxy Note 5 Back Cover Replacement: paso 2, imagen 1 de 1
    • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
  3. Samsung Galaxy Note 5 Back Cover Replacement: paso 3, imagen 1 de 1
    • If you do it hardly, you need much more heat especially the edged side.
    • Slipping a playing card through the gap is a good way to loosen up the adhesive.
  4. Samsung Galaxy Note 5 Back Cover Replacement: paso 4, imagen 1 de 1
    • Remove the back cover. The white stripe is the sticker.
Conclusión
45 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,822 Reputación
62 Guías creadas
9 comentarios
What about putting the one back on?
rcf917 - Contestar
will it go back on and stay on without new adhesive?
dfasdfjiun - Contestar
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
Witrigs - Contestar
How do I remove the sticky part
Marcelino Lopez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 37
Todo El Tiempo: 108,849
