Introducción
Use this guide to replace the rear-facing camera on your Galaxy Note 4.
Qué necesitas
Resumen del Video
Take away the back cover and battery easily. Don't forget to remove SIM card and S Pen.
Before removing motherboard, we have to remove LCD screen. You can see more details on Samsung Galaxy Note 4 LCD screen replacement.
If just removing the rear camera it is not necessary to remove the LCD from the assembly. simply unscrew the one screw located on the left side of the motherboard and disconnect flex cables with a plastic spudger, keeping in mind the two connections underneath the board where the LCD connects. You run less risk of damage to the display this way.
30 personas más completaron esta guía.
14 comentarios
Just look at the photo and Google it. "The opening tool" or HH-5A
Hello good day! Could someone tell me what do you call these platelets circuits that have bonded to the housing samsung galaxy note 4 I circled in red the following .. images.
[img]http://i.imgur.com/2vvZ2dK.jpg?1[/img]
[img]http://i.imgur.com/ViV1TUL.jpg?1[/img]
What could you do if just the glass was broken on your camera lens but camera still worked?
sheets83 -
if you only have the glass broken you *MIGHT* be able to just replace the glass cover but there is a huge risk of glass and dust contamination ruining the camera anyways. I personally had this happen after replacing the glass cover and now have black splotches all over even after I tried my damnest to control for dust.
