Saltar al contenido principal
Samsung Galaxy Note 4 Rear Facing Camera Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Note 4 Rear Facing Camera Replacement, Rear Facing Camera: paso 1, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement, Rear Facing Camera: paso 1, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement, Rear Facing Camera: paso 1, imagen 3 de 3
    • Take away the back cover and battery easily. Don't forget to remove SIM card and S Pen.
  2. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 2, imagen 3 de 3
    • Remove all 16 screws together on the back.
  3. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 3, imagen 3 de 3
    • Cut LCD screen sticker, loosen clasps around battery slot and push the whole front assembly out from middle housing.
  4. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 4, imagen 1 de 1
    • We can see the motherboard now and the rear camera is connected by a connector on the back of motherboard. So we have to remove motherboard before removing rear camera.
  5. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 5, imagen 3 de 3
    • Before removing motherboard, we have to remove LCD screen. You can see more details on Samsung Galaxy Note 4 LCD screen replacement.
    • If just removing the rear camera it is not necessary to remove the LCD from the assembly. simply unscrew the one screw located on the left side of the motherboard and disconnect flex cables with a plastic spudger, keeping in mind the two connections underneath the board where the LCD connects. You run less risk of damage to the display this way.
  6. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 6, imagen 3 de 3
    • Release connectors which connecting with motherboard.
  7. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 7, imagen 3 de 3
    • Remove the screws, you can remove the top one only. Pry up and release USB board connector on the back.
    • Finally, remove motherboard.
  8. Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 8, imagen 1 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 8, imagen 2 de 3 Samsung Galaxy Note 4 Rear Facing Camera Replacement: paso 8, imagen 3 de 3
    • Release rear camera connector and remove it.
Conclusión
30 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,861 Reputación
62 Guías creadas
14 comentarios
What is the tool, they use in step 5?
Sara Lee - Contestar
Just look at the photo and Google it. "The opening tool" or HH-5A
isaactannermadsen - Contestar
Hello good day! Could someone tell me what do you call these platelets circuits that have bonded to the housing samsung galaxy note 4 I circled in red the following .. images.
[img]http://i.imgur.com/2vvZ2dK.jpg?1[/img]
[img]http://i.imgur.com/ViV1TUL.jpg?1[/img]
elisangelops - Contestar
What could you do if just the glass was broken on your camera lens but camera still worked?
sheets83 -
if you only have the glass broken you *MIGHT* be able to just replace the glass cover but there is a huge risk of glass and dust contamination ruining the camera anyways. I personally had this happen after replacing the glass cover and now have black splotches all over even after I tried my damnest to control for dust.
Michael Goelz -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 49,110
