Saltar al contenido principal
Samsung Galaxy Note 3 Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove the rear case: paso 1, imagen 1 de 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: paso 2, imagen 1 de 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: paso 2, imagen 2 de 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: paso 3, imagen 1 de 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: paso 3, imagen 2 de 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Headphone Jack Replacement, S Pen: paso 4, imagen 1 de 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Headphone Jack Replacement, Unscrew Back Chassis: paso 5, imagen 1 de 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Back Chassis: paso 6, imagen 1 de 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: paso 7, imagen 1 de 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: paso 7, imagen 2 de 2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: paso 8, imagen 1 de 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: paso 8, imagen 2 de 2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Headphone Jack Replacement, Motherboard Removal: paso 9, imagen 1 de 1
    • Pull up on the motherboard with tweezers.
  10. Samsung Galaxy Note 3 Headphone Jack Replacement, Spudger Tool Placement: paso 10, imagen 1 de 1
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Headphone Jack Replacement, Lift to Separate Headphone Jack: paso 11, imagen 1 de 1
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
Conclusión
23 personas más completaron esta guía.
Brittany Gail
Miembro Desde 09/23/14
8,468 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 2-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 14,820
