Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Note 10.1 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: paso 1, imagen 1 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: paso 1, imagen 2 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: paso 1, imagen 3 de 3
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
    Pregunta a FixBot
    Agregar Comentario
  2. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: paso 2, imagen 1 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: paso 2, imagen 2 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: paso 2, imagen 3 de 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
    Pregunta a FixBot
    Agregar Comentario
  3. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: paso 3, imagen 1 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: paso 3, imagen 2 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: paso 3, imagen 3 de 3
    • Carefully remove all of the ribbons that connect over the battery.
    Pregunta a FixBot
    Agregar Comentario
  4. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: paso 4, imagen 1 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: paso 4, imagen 2 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: paso 4, imagen 3 de 3
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
    Pregunta a FixBot
    Agregar Comentario
  5. Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Flip the tablet 180 degrees for this step so the motherboard is easier to access.
    • Disconnect the cable connectors from the motherboard by gently lifting the connection hubs.
    • Remove each ribbon cable by lifting the locking mechanism on the casing holding the cable.
    • Gently pull the ribbon cable from the casing with your fingers or tweezers.
    • Carefully remove ribbon cables. Ribbon cables are easy to damage and may not always appear damaged. Any damage could potentially cause your device not to work.
    Pregunta a FixBot
    Agregar Comentario
  6. Samsung Galaxy Note 10.1 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the motherboard by gently sliding it out of its casing.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
5 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 50
Todo El Tiempo: 3,477
