Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
In this guide, you will learn how to replace the motherboard in a Samsung Galaxy Note 10.1 2012 tablet.
The motherboard connects all of the other components together so that the tablet can operate. Without it, nothing else would function.
Before using this guide, check out the troubleshooting page for the tablet. This is a crucial step because it is difficult to determine when a motherboard is faulty. The issue could be caused by another component, rather than the motherboard itself.
  1. This is the back of the device and where you will begin to take it apart It is neccesary to remove this piece first before removing the bigger back piece. Use the plastic opening tools to pry along the indicated box.
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver. Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top. Remove the back cover.
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. Carefully remove all of the ribbons that connect over the battery from the locations indicated by the yellow circles. Carefully remove all of the ribbons that connect over the battery from the locations indicated by the yellow circles. Carefully remove all of the ribbons that connect over the battery from the locations indicated by the yellow circles.
    • Carefully remove all of the ribbons that connect over the battery from the locations indicated by the yellow circles.
  5. Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver. Disconnect the battery from the location indicated by a yellow circle Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery from the location indicated by a yellow circle
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
  6. Flip the tablet 180 degrees for this step so the motherboard is easier to access. Disconnect the cable connectors from the motherboard by gently lifting the connection hubs. Remove each ribbon cable by lifting the locking mechanism on the casing holding the cable.
    • Flip the tablet 180 degrees for this step so the motherboard is easier to access.
    • Disconnect the cable connectors from the motherboard by gently lifting the connection hubs.
    • Remove each ribbon cable by lifting the locking mechanism on the casing holding the cable.
    • Gently pull the ribbon cable from the casing with your fingers or tweezers.
    • Carefully remove ribbon cables. Ribbon cables are easy to damage and may not always appear damaged. Any damage could potentially cause your device not to work.
  7. Remove the motherboard by gently sliding it out of its casing.
    • Remove the motherboard by gently sliding it out of its casing.
Conclusión
Rachel Dykes
Miembro Desde 04/11/19
157 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 27
Ultimos 30 días: 117
Todo El Tiempo: 892
