Saltar al contenido principal
Samsung Galaxy Note 10.1 2014 Charging Port Replacement
Qué necesitas
  1. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Case: paso 1, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Case: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Battery: paso 2, imagen 1 de 1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: paso 3, imagen 1 de 1
    Phillips #000 Screwdriver
    $5.49
    Comprar
  4. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement: paso 4, imagen 2 de 2
    Spudger
    $2.99
    Comprar
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
  5. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Charging Port: paso 5, imagen 1 de 1
    • Using the PH000 screwdriver, remove the two black 3mm screws at the bottom of the device.
  6. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement: paso 6, imagen 2 de 2
    • After disconnecting the two blue electronic connectors, unhinge the metal part of the charging port with the black nylon spudger.
    • Make sure to also disconnect the other end of the ribbon as well by pushing back the thin black metal bar.
Conclusión
14 personas más completaron esta guía.
Joseph Rasico
Miembro Desde 02/20/17
2,200 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Miembros
6 Guías creadas
4 comentarios
Great guide. It helped me find the right component to order and gave me confidence to fix it myself. Actually the steps can be shortened. The battery does not need to be removed. So you need to do step 1 (remove the cover), first part of step 2 (remove the flat cable of the charge plug), step 5 and 6. Step 7 should be to replace the old part with the new part. And then of course the reversal of reconnecting via steps 6, 5, 2 and 1.
John Aap - Contestar
Great guide. thanks.
at the SIM card slot corner, there is a little cylinder connected to the SIM card slot, what is it. i accidentally cut the ribbon between the SIM card slot and this piece.
Anas Sibaii - Contestar
This guide enabled me to replace a bad charging port.
Note - the replacement microUSB port didn’t have the little chrome frame around the port - so I had to carefully scavenge the frame from the old one just to give the new port a little more support when plugging in a cable.
I’m going to use a magnetic charging adapter to reduce the wear and tear on the port, but this one saved the day.
Mister Muscles - Contestar
Although I have changed this flat cable and also the relative micro USB connector and have installed the driver on the PC, the Tablet is not recognized, even if it charges the battery. I also tried to change micro USB cable and USB port on PC : - ((((
giovanni_gola - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 49
Todo El Tiempo: 12,894
