Saltar al contenido principal
Samsung Galaxy Nexus SIM Card Replacement
Qué necesitas
  1. Samsung Galaxy Nexus SIM Card Replacement, Back of Phone: paso 1, imagen 1 de 1
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Samsung Galaxy Nexus SIM Card Replacement, Removal of Back Cover: paso 2, imagen 1 de 3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Back Cover: paso 2, imagen 2 de 3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Back Cover: paso 2, imagen 3 de 3
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Samsung Galaxy Nexus SIM Card Replacement, Removal of Battery: paso 3, imagen 1 de 3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Battery: paso 3, imagen 2 de 3 Samsung Galaxy Nexus SIM Card Replacement, Removal of Battery: paso 3, imagen 3 de 3
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Samsung Galaxy Nexus SIM Card Replacement, Back Cover of Phone: paso 4, imagen 1 de 3 Samsung Galaxy Nexus SIM Card Replacement, Back Cover of Phone: paso 4, imagen 2 de 3 Samsung Galaxy Nexus SIM Card Replacement, Back Cover of Phone: paso 4, imagen 3 de 3
    • Using your fingers pull the Sim card out.
    • This is a Verizon phone, however we are using a AT&T Sim card as an example as to where to put the sim card.
Conclusión
3 personas más completaron esta guía.
Stephan Williams
Miembro Desde 09/22/14
1,482 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,917
