Saltar al contenido principal
Samsung Galaxy Mega USB Board Replacement
Qué necesitas
  1. Samsung Galaxy Mega USB Board Replacement, Battery: paso 1, imagen 1 de 3 Samsung Galaxy Mega USB Board Replacement, Battery: paso 1, imagen 2 de 3 Samsung Galaxy Mega USB Board Replacement, Battery: paso 1, imagen 3 de 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega USB Board Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Mega USB Board Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Mega USB Board Replacement: paso 2, imagen 3 de 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega USB Board Replacement, Midframe: paso 3, imagen 1 de 3 Samsung Galaxy Mega USB Board Replacement, Midframe: paso 3, imagen 2 de 3 Samsung Galaxy Mega USB Board Replacement, Midframe: paso 3, imagen 3 de 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega USB Board Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Mega USB Board Replacement: paso 4, imagen 2 de 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega USB Board Replacement, USB Board: paso 5, imagen 1 de 1
    • This circuit board is the charging port assembly.
  6. Samsung Galaxy Mega USB Board Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Mega USB Board Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Mega USB Board Replacement: paso 6, imagen 3 de 3
    • Lift up on the clamp with your finger to disconnect the connector.
    • Lift up on the clamp with your finger to disconnect the connection to the mother board.
    • Grasp cable head and lift up to disconnect the cable head.
  7. Samsung Galaxy Mega USB Board Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Mega USB Board Replacement: paso 7, imagen 2 de 2
    • Use your fingers to gently remove charging port.
Conclusión
10 personas más completaron esta guía.
Aaron Fulton
Miembro Desde 02/04/16
1,246 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 17-2, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 8,682
