Saltar al contenido principal
Introducción
This guide instructs on how to replace the back panel audio speaker.
Partes
No se especificaron partes.
  1. Before starting, ensure device is completely turned off. On the back of phone, locate the slot on the top left corner. Insert plastic opening tool or fingernail and pull up on the back plate.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  3. Insert fingernail into the slot on bottom of battery and gently pull up. Remove the battery. Remove the battery.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  4. Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker. Gently insert plastic opening tool through the inside groove of the speaker assembly. Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
    • Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker.
    • Gently insert plastic opening tool through the inside groove of the speaker assembly.
    • Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
Conclusión
Una persona más ha completado esta guía.
nithin
Miembro Desde 04/02/16
137 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 17-2, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Miembros
8 Guías creadas
Añadir comentario
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
Global: 662
