Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide instructs on how to replace the front facing speaker and LED blinker.
  1. Before starting, ensure device is completely turned off. On the back of phone, locate the slot on the top left corner. Insert plastic opening tool or fingernail and pull up on the back plate.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Insert fingernail into the slot on bottom of battery and gently pull up. Remove the battery. Remove the battery.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Remove the 14 3.45 mm Phillips #000 screws from the assembly. Gently, insert plastic opening tool into seam above the volume buttons of your phone. You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Slowly slide plastic opening tool around the device to release all the connectors internal to the device. The device should easily come apart after the plastic opening tool is slid around the entire device.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Remove the black 2.55 mm Phillips #000 screw.
    • Remove the black 2.55 mm Phillips #000 screw.
  6. Remove the metal cover with the plastic opening tool.
    • Remove the metal cover with the plastic opening tool.
  7. Remove the motherboard clip from speaker assembly to the motherboard. Gently lift the speaker and LED assembly out of the device.
    • Remove the motherboard clip from speaker assembly to the motherboard.
    • Gently lift the speaker and LED assembly out of the device.
    • Speaker assembly may be glued to the device, gently pry until it releases.
Conclusión
3 personas más completaron esta guía.
Max Rathman
Miembro Desde 04/02/16
843 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 17-2, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 791
