Saltar al contenido principal
Samsung Galaxy Media Player 5 Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Media Player 5 Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 2 Samsung Galaxy Media Player 5 Headphone Jack Replacement, Headphone Jack: paso 1, imagen 2 de 2
    • Remove the SD Memory Card before taking the device apart. Using the screwdriver, remove the 10mm Phillips screw that is near the SD Memory Card port.
  2. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Remove the white caps which are covering the screws that are located on either side of the charging port.
    • You may have to use a low heat blow dryer for 5 to 10 seconds, or other equivalent heat source to loosen the adhesive.
  3. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Continue to unscrew the two 10mm Phillips Screws from the bottom of the device.
  4. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Starting from the bottom and working around, use an opening pick to separate the front cover housing from the back cover housing.
    • You will hear a popping sound, indicating the separation.
  5. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Take the back housing cover off of the device.
  6. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 6, imagen 2 de 2
    • Detach the tab the battery is attached to and the battery using the prying tool in an upward motion.
    • Adhesive is behind the battery, but it is not strong.
  7. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 7, imagen 2 de 2
    • Remove the headphone jack by unscrewing the 10mm Phillips screw to its left then proceed to pry up the tab that attaches the headphone jack to the motherboard.
  8. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Place new the headphone jack back into its position and connect the tab, then screw it back into place.
  9. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 9, imagen 2 de 2
    • Insert the battery into its position, and reconnect its tab onto the motherboard.
  10. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 10, imagen 1 de 1
    • Now put the rear housing cover on the device, starting from its bottom side, and snap the edges all the way around to close the device.
  11. Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 11, imagen 1 de 3 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 11, imagen 2 de 3 Samsung Galaxy Media Player 5 Headphone Jack Replacement: paso 11, imagen 3 de 3
    • Lastly reinsert the screws at the bottom of the device, as well as the screw inside the SD Memory Card port.
Conclusión
4 personas más completaron esta guía.
China Ayala
Miembro Desde 03/05/15
584 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 455
