Saltar al contenido principal
Samsung Galaxy Luna Battery Replacement
Qué necesitas
  1. Samsung Galaxy Luna Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the device is powered off before attempting to disassemble it.
    • Use a plastic opening tool, or your fingernail to to take off the rear case by prying the divot to the left of the camera.
  2. Samsung Galaxy Luna Battery  Replacement: paso 2, imagen 1 de 1
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy Luna Battery  Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Luna Battery  Replacement: paso 3, imagen 2 de 2
    • Locate the notch in the lower right corner of the battery then lift the battery out.
Conclusión
Balqees
Miembro Desde 02/14/18
186 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S6-G1, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S6G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 914
