Saltar al contenido principal
Samsung Galaxy Light USB Charging Port Replacement
Qué necesitas
  1. Samsung Galaxy Light USB Charging Port Replacement, Remove back cover: paso 1, imagen 1 de 1
    • Remove the back cover with the opening tool to reveal the battery
  2. Samsung Galaxy Light USB Charging Port Replacement, Remove battery: paso 2, imagen 1 de 1
    • Now remove the battery and keep it somewhere safe for now
  3. Samsung Galaxy Light USB Charging Port Replacement, Unscrew motherboard from plastic protection: paso 3, imagen 1 de 1
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  4. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: paso 4, imagen 1 de 3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: paso 4, imagen 2 de 3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: paso 4, imagen 3 de 3
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  5. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: paso 5, imagen 1 de 2 Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: paso 5, imagen 2 de 2
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
Conclusión
3 personas más completaron esta guía.
Diandra
Miembro Desde 10/16/14
210 Reputación
2 Guías creadas
Equipo
3 comentarios
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - Contestar
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - Contestar
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,103
