Saltar al contenido principal
Samsung Galaxy Light Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Light Motherboard Replacement, Remove Back Cover: paso 1, imagen 1 de 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Motherboard Replacement, Remove Battery: paso 2, imagen 1 de 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Motherboard Replacement, Unscrew Midframe: paso 3, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Motherboard Replacement, Remove Midframe: paso 4, imagen 1 de 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: paso 5, imagen 1 de 3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: paso 5, imagen 2 de 3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: paso 5, imagen 3 de 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
Conclusión
7 personas más completaron esta guía.
Diandra
Miembro Desde 10/16/14
210 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,219
