Saltar al contenido principal
Samsung Galaxy J7 Volume Button Replacement
Qué necesitas
  1. Samsung Galaxy J7 Volume Button Replacement, Back Cover: paso 1, imagen 1 de 2 Samsung Galaxy J7 Volume Button Replacement, Back Cover: paso 1, imagen 2 de 2
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Volume Button Replacement, Volume Button: paso 2, imagen 1 de 1
    • Once your device's back has been disassembled, grab the panel that has the volume buttons.
  3. Samsung Galaxy J7 Volume Button Replacement: paso 3, imagen 1 de 1
    • Turn the panel around and locate the volume button.
  4. Samsung Galaxy J7 Volume Button Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Locate the rubber tabs and gently lift them up from their inserts with the tweezers.
  5. Samsung Galaxy J7 Volume Button Replacement: paso 5, imagen 1 de 1
    • Push button inward from the outside to remove.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 1,487
