Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy J7 V Rear Camera Replacement
Qué necesitas
  1. Samsung Galaxy J7 V Rear Camera Replacement, Screen: paso 1, imagen 1 de 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Rear Camera Replacement: paso 2, imagen 1 de 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Rear Camera Replacement: paso 3, imagen 1 de 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Rear Camera Replacement, Home button: paso 4, imagen 1 de 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Rear Camera Replacement: paso 5, imagen 1 de 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: paso 6, imagen 1 de 2 Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: paso 6, imagen 2 de 2
    • Use the indent on the right side of the phone to lift up the backing
    • With the phone faced downwards, remove the backing of the case, lifting up from the right side
  7. Samsung Galaxy J7 V Rear Camera Replacement, Remove the battery: paso 7, imagen 1 de 1
    • Carefully remove the battery by lifting the bottom side, and then fully remove the battery
  8. Samsung Galaxy J7 V Rear Camera Replacement, Motherboard: paso 8, imagen 1 de 1
    • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
  9. Samsung Galaxy J7 V Rear Camera Replacement: paso 9, imagen 1 de 1
    • Flip the phone to the back side where the battery was removed.
    • Apply pressure with your hands to pop the midframe off.
  10. Samsung Galaxy J7 V Rear Camera Replacement: paso 10, imagen 1 de 2 Samsung Galaxy J7 V Rear Camera Replacement: paso 10, imagen 2 de 2
    • Flip the phone back over.
    • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
    • Place a few iFixit opening picks beneath the motherboard.
    • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
    • Lift the motherboard using the iFixit opening picks.
  11. Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: paso 11, imagen 1 de 3 Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: paso 11, imagen 2 de 3 Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use the tweezers to detach the tab securing the rear camera.
    • Use your fingers to pull the camera away from the motherboard.
Conclusión
2 personas más completaron esta guía.
1Guía Comentario
goood
شكرا كتير لقد استفت من الموقع جدا واتمنى ان اواصل معرفه واطلاع على كل جديد
ageedaa11 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 881
