Saltar al contenido principal
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
Qué necesitas
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: paso 1, imagen 1 de 1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 2, imagen 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 2, imagen 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 2, imagen 3 de 3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 3, imagen 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 3, imagen 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 3, imagen 3 de 3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 4, imagen 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 4, imagen 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 4, imagen 3 de 3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 5, imagen 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 5, imagen 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: paso 5, imagen 3 de 3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: paso 6, imagen 1 de 2 Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: paso 6, imagen 2 de 2
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Conclusión
Una persona más ha completado esta guía.
Brandon Mendoza
Miembro Desde 01/29/18
646 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G5, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,186
