Herramientas
Partes
  1. Flip the phone face down on its screen.
    • Flip the phone face down on its screen.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Pull up on the small  indention on the right side edge and remove the back portion  of the phone. Pull up on the small  indention on the right side edge and remove the back portion  of the phone. Pull up on the small  indention on the right side edge and remove the back portion  of the phone.
    • Pull up on the small indention on the right side edge and remove the back portion of the phone.
  4. After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it. After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it. After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
    • After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
Conclusión
Una persona más ha completado esta guía.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 25
Todo El Tiempo: 121
