Saltar al contenido principal
Samsung Galaxy J1 Midframe Replacement
Qué necesitas
  1. Samsung Galaxy J1 Midframe Replacement, Midframe: paso 1, imagen 1 de 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Midframe Replacement: paso 2, imagen 1 de 2 Samsung Galaxy J1 Midframe Replacement: paso 2, imagen 2 de 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Midframe Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Midframe Replacement: paso 4, imagen 1 de 3 Samsung Galaxy J1 Midframe Replacement: paso 4, imagen 2 de 3 Samsung Galaxy J1 Midframe Replacement: paso 4, imagen 3 de 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
Conclusión
6 personas más completaron esta guía.
Sean Kramer
Miembro Desde 02/14/18
1,467 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S5-G4, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 2,107
