Saltar al contenido principal
Samsung Galaxy Grand Prime Micro USB Port Replacement
Qué necesitas
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: paso 1, imagen 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: paso 1, imagen 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: paso 2, imagen 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: paso 2, imagen 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: paso 2, imagen 3 de 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: paso 3, imagen 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: paso 3, imagen 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: paso 3, imagen 3 de 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 4, imagen 2 de 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 5, imagen 2 de 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: paso 6, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: paso 6, imagen 2 de 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: paso 7, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: paso 7, imagen 2 de 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 8, imagen 2 de 2
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: paso 9, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: paso 9, imagen 2 de 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 10, imagen 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 10, imagen 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 10, imagen 3 de 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 11, imagen 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: paso 11, imagen 2 de 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: paso 12, imagen 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: paso 12, imagen 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: paso 12, imagen 3 de 3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
Conclusión
33 personas más completaron esta guía.
Kyle Ruff
Miembro Desde 02/04/16
6,521 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 17-3, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 87
Todo El Tiempo: 34,111
