Saltar al contenido principal
Samsung Galaxy Grand Prime Battery Replacement
Qué necesitas
  1. Samsung Galaxy Grand Prime Battery Replacement, Battery: paso 1, imagen 1 de 3 Samsung Galaxy Grand Prime Battery Replacement, Battery: paso 1, imagen 2 de 3 Samsung Galaxy Grand Prime Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: paso 2, imagen 1 de 3 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: paso 2, imagen 2 de 3 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: paso 2, imagen 3 de 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Conclusión
44 personas más completaron esta guía.
Equipo
USF Tampa, Team 17-3, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Miembros
12 Guías creadas
Un comentario
Should I assume that it is the battery at fault when about 3 location seems a bit warm on the board when leaving the charger on?
Noelu Toyotomi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 24
Ultimos 30 días: 100
Todo El Tiempo: 12,739
